@Trash80toHP_Mini I need your help. I'm at my wits end trying to get my adapter cable (above) to work. The cable is now much messier, after a string of failed attempts:
Matching up all the pins was pretty easy (Data0 to Data0, ACK to ACK etc etc) - except for the Ground wires. There's so many of them (especially on the IDC 50 end) - and I'm not sure what I'm supposed to do with them!
You'll see in my first picture in the previous post, I had chopped off all the ground wires that I didn't have an associated connection for on my HDI-30 connector end. When I plugged it in, the SCSI2SD activity light just came on solid and the Mac would not boot. (Note that I've sorted out my SCSI termination issues - the SCSI2SD terminator is disabled, since the Asante Card is terminated).
So then I connected up all of the unused ground wires and linked them up to other (random) ground wires on the HDI-30 (as above pic). It is much more promising - the Mac now boots successfully - but very shortly after it bombs out with a bus error. Strangely, the
very first time I booted up, everything seemed to work for quite a few minutes until I got a bomb error - but ever since then I get an immediate bomb after startup.
A few questions:
1. Is there a specific order in which the Ground wires should be connected? i.e. should certain ground wires be paired up with other lines, such as REQ/GND, IO/GND? If so, how would I figure out what the pairs are?
2. What am I supposed to do with all the odd ground wires on the IDC 50 cable (1, 3, 5 ...49)? In the pic above, I attempted to join them all together - but no joy. There's also some even ground wires on the IDC 50.
3. I'm unsure if pins 23 and 27 on the IDC are ground wires, or "reserved" wires (there's conflicting info online) - although I've tried them both connected and disconnected, but no joy either way
There's 10 ground wires on the HDI-30, and 31 on the IDC 50...
