Hi, everyone. Finally de-lurking!
I'm the process of resuscitating a Macintosh IIfx. After an exploding C1, resulting in me going ahead and replacing all of the big tantalums, the only two electrolytic SMDs, and the remaining axial capacitors, replacing the batteries, and repairing a trace between battery 1 and C24, I am having one last little issue. From cold, the IIfx either takes quite a few starts (like cranking an old engine), or a direct connection of power to the on/off pin of the power supply for 5+ seconds to start up. Oddly, and maybe coincidentally, it seems like it takes fewer when starting it over ADB than the rear switch. I thought maybe there was a capacitor that just wasn't charging properly, but everything seems to check out okay, and if I shut down and start it up again within a few seconds, it'll fire right back up.
I'm hoping to get some ideas of what I should check from people who may have been down this road before. My current theories are to crack open the power supply to recap it, in case 5v is just slow to warm up, or potentially replacing transistors at Q2 or Q3 that may be slow to respond (though they seem to both be operating fine?). Anything else I should be checking?
Thanks for any ideas at all, even if they are just to spark some other ideas!
