Maxing out the 9500
Gil
Anyone wanna sell me one of these ROM's?
That is, if my 9500 is willing to show me it's RAM slots. :) (seriously, I'm terrified of that thing)
Gil
You can always do a Full-ATX conversion.
How would I go about doing that? I've never worked with cases much before, and when I have, I almost always broke something. :)
I'd probably be willing to gut it and send the parts to anyone who would be up for the challenge, but that could be risky.
Bunsen
Admin-Witchfinder-General
Sonnet Tempo USB2/FireWire PCI.
I realise you have lots and lots of slots, and you're going for SATA drives anyway, but if you want to save a slot and can stand ATA drives, you could also consider the Sonnet Tempo Trio - Firewire, USB and ATA on one card.
I think I heard from someone on here that SIIG's matching card is Mac compatible too.
Leografix
Hmm...
I´m upgrading my 9600 right now, too. To me it doesn´t make much sense to use SATA so I took two Sonnet 133 ATA cards, one serving the CD ROM and three disks (80 GB each) and the other one 4 disks (also 80 GB each) to the bottom of the 9600 case by using two double carriers from a G4 system. It runs with a Sonnet G4 800 MHz but with the classic OS solely. I never had much fun in using OS X on an old world machine.
The double carrier system on bottom of the case blocks three or four PCI slots (depending on the height of a hard disk) but as I´m only in need of a high speed ethernet and a SCSI card (for external tape backup devices) this doesn´t bother me that much.
Alltogether this box acts as a local network ShareIP server - I once thought about configuring it as an old world high end audio production system but a gave a QucikSilver a better chance in this: can run classic OS and Mac OS X and bounced to double 1,6 GHz.
J
Leografix
Well, SATA doesn't justify the costs for itself in an old world system, besides this I think that older hard- and software doesn't take that much advantage of a SATA system as promised by Sonnet and others.
J
paws
I want a SATA card for my 7500 for the sole reason that I'd like to be able to buy new, quiet disks that'll be useful even if the PowerMac dies and I decide not to get another one... Buying used IDE drives (or used SCSI drives and ->50 pin adaptors) just seems like a bit of a waste when you can get brand new SATA drives for next to nothing.
Gil
That's exactly how I see it.
Lateralus
If somebody is looking to upgrade an older Mac and doesn't already have an ATA-100/133 setup, I think it'd be stupid to pursue one over an S-ATA setup.
We're at the point where S-ATA is both cheaper and more widespread.
Unknown_K
It depends, most of the throw away computers and drives you find today ane still EIDE, and I don't see the need for a 200GB+ drive in a 9500 so ATA cards (now worth much less then they used to, and are OS 7 compatible to boot) are still nice to have on PCI Powermacs.
Lateralus
But if you're looking to upgrade an older machine, especially going to the extent of upgrading the entire drive system and buying a controller card, chances are you aren't going to do it with thrown away parts.
S-ATA cards are cheap. Large S-ATA drives can be had for under $50 from places like NewEgg. IDE/ATA is just, IMO, silly to pursue if you planning on buying all the parts you're going to need anyways.
Gil
Who says it has to be 200GB+? I was gonna put in a 10 GB, at the max. I use hardly any storage.
Now my 500GB USB Hard Drive, is a SATA drive, as discovered by a Google search. I might pop the case open and shove it in my 9500 if I get the SATA card.
Gil
And we're back, after a 4+ hour dreadful attempt t oget video. Turns out my one and only monitor, in which 5 computers are sharing, finally kicked off.
Anywho, I got my nice little 15 inch LCDer hooked up. Everything is beautiful.
I have this generic FireWire card I got a few years ago. I think its the exact same one as on the OWC store, but I bought mine from eBay. I read somewhere here that ANY OCHI compatible card will work with OS 8.5+? This is OHCI compatbile, and have it installed in my 9500 running OS 9. However, it's not doing anything. I don't know if I need a driver, as it's generic. System Profiler just lists it as "PCI Card" with nothing specific in the card data/description.
Any ideas?
I suppose that the system recognizes the card, is better than nothing.
paws
Have you tried plugging anything into it?
My Echo soundcard shows up as 'PCI Card' and works fine.
