Trash80toHP_Mini
NIGHT STALKER
I'm getting ready to do what I've been calling the "Machine Pin Hack" to a couple of boards and I'd like some advice on how to go about getting the best solder joint.
Machine pins are:
___very high quality, reliability and priced alternatives to standard pin/socket connections . .
___they consist of snap-off plastic packaged SIP or DIP rows of lathe turned(?) conical socket/soldertail pins . . .
The "Machine Pin Hack" mates these conical sockets to the soldertail/solder "cones" on the underside of a thru-hole PDS, NuBus, etc. slot or socket connection.
Question:
I've been planning to fill the of the Machine Pin's conical female cones with solder paste and then soldering/re-flowing each connection, mating the solder of the PCB with the solder paste in the machine pin.
Will this method give me a strong, reliable connection for this soldertail to pin conversion? :?:
I have also considered:
___filling the cones with flux and using standard leaded solder.
___tinning the insides of the Machine Pin's cones with standard solder.
___tinning the insides of the Machine Pin's cones with low temperature solder, similar to Chip-Quick.
Any suggestions from experienced rework a/o basic soldering technique gurus would be much appreciated by this soldering noob.
Machine pins are:
Question:
