MacIP in Professional MachTen
LarBob
I'm trying to get a network up using macipgw and an AsantePrint, and it actually fully works on the Mac side of things, but it doesn't seem to work through Professional MachTen. I have the networking pane configured properly (at0 IP 172.16.2.2, gateway 172.16.2.1, DNS 8.8.8.8, search domain macip.net), and it seems to bring the at0 interface up at boot, but I can't actually ping out or reach anything. Setting the IP to 0.0.0.0 (in order to have it dynamically find the zone and get an IP) also works and sets the IP to 172.16.2.2 but I still can't actually use the network. Anyone have ideas?
mactjaap
Nice to hear your trying my stuff.
I build MacIP VM and Rpi images to make it possible to use IP and LocalTalk. But you can use it in a network. Not sure what solution you are using. VM or Rpi?
Don’t know MachTen. But that is my problem. I will have a look.
LarBob
Thanks for making those images! MacIPgw-VM is working perfectly in this instance, it's just something to do with how MachTen needs to be configured.
As an aside, it seems that the VM has quite a few things that depend on the name of the interface being `enp0s3`. I was trying to run the VM in something besides VirtualBox, which resulted in a different interface name. I tried to find everything that depended on the interface name and got everything working except for DNS on the Mac side. So, as an alternate solution, I created a udev rule in /etc/udev/rules.d called 60-net.conf with the contents
ACTION=="add", SUBSYSTEM=="net", DRIVERS=="?*", ATTR{address}=="interface MAC address here", NAME="enp0s3"
, which worked around the issue perfectly. This may help others in the future if you want to mention it on your site.
