fergycool
Just got myself a Macintosh SE yesterday (finally!). I bought it on eBay and there was a risk in shipping (which I was OK with). However, when it arrived it turned on fine (although the internal SCSI drive is dead). It boots fine from a 700k System 6.0.8 floppy. So I was very happy.
However, after shutting it down, then powering back on an hour later it is dead. No lights or sound at all.
I opened up the case (after making myself one of those discharge tools).
I disconnected the SCSI drive from both the SCSI bus and the Molex connector. I removed the logic board. The battery looked fine, but I still snapped its legs and removed it. There is no corrosion on the board. In fact it looks quite clean!
I tested the power from the drive Molex connector and neither the 5v or 12v sides give any reading at all. Not suprising as the PSU fan does not kick at all when powered on.
From reading on here I guess that the PSU was on its last legs and is now dead. So it will need recapping or replacing.
Thank you.
Thank you.
