Are you using the stock harness? If so, I’d get the +5V leads upgraded.
I just edited my previous post with a link to a thread that gives more info.I'm using the new harness that came with Bolle's grayscale card. By upgrade you mean thicker gauge wiring?
I didn’t check the wire gauge of the 5V cables coming out of my Sony PSU.Just took a look and Bolle's harness has thicker gauge wires than the stock harness. What's interesting though, is the power supply to the analog board, those wires look similar in gauge to the stock harness. I'm probably not getting enough voltage to the analog board.
Make sure to scroll to the top to see @zigzagjoe ‘s initial post which is more useful than my response which I directly linked you toThanks for the thread link.
Just make sure whatever solution you employ uses 16 or 18 AWG throughout rather than 22.I'll try to measure the voltage at the analog board and then see if I can send some wires directly from the PSU to the logic board via the connector.
Your PSU is new build: what AWG does it use (it’s printed on the side)? I still think the stock harness will be the main cause of voltage drop in your case (and in any case) as it is a longer run. But you can measure this.
If you are using one of @tt replacement PSUs, you may find it worthwhile to eliminate the molex connector inside the PSU. Additional connectors will cause further voltage drop, and there's no need to be able to disconnect the PSU harness from the PSU.I am running into the issue while using Bolle's harness (not the stock one).
From your thread, it looks like the stock harness would have issues but note that with the stock harness and the combo card + daystar, I'm actually doing fine (ie. no crash) albeit with the voltage sitting around 4.85v.
But with the grayscale card + Bolle's harness, I'm getting a crash on cold boot only. I can't obviously try the stock harness in this setup since I need to new harness to use the grayscale card
So at this point if it's due to the wire gauge, the only remaining location is the new PSU. It's wires going to the analog board seem the same gauge as the stock harness wires (probably 22 gauge). So I can upgrade those in that wiring and then also do what @zigzagjoe suggested in your thread and add some wires going directly from the PSU to the logic board also.
Also, keep in mind the stock harness wires have unusually thick insulation for 22 gauge wires.
That’s a great improvement.Everything works now. The voltage improved from 4.7V to 4.85V now with the 16 gauge wires with all the components in place. Thanks for the tip @croissantking and @zigzagjoe!
Has it fully resolved your crash on cold boot?
This is what always happens - I hate that feelingLOL, of course I jinxed myself.. the crash is back.
