The battery dead one either has a blown fuse, or more likely, the ADC that reads the batteries voltage needs replaced. I am unsure if the ADC is integrated into the PMU IC or not. all the new microcontrollers have all that crap built in, but the old ones may not.yes 4 out of 6 boards, now powerup the stock hard drive with a fresh boost reg installed. the other 2 are just dead they don't power up at all.
i still have 6 bad boards, lol but atleast 4 of them will powerup the hard drive.
1 powers up, boots from the hard drive, but shuts its self down once booted up. saying battery is dead... when its fully charged, and when plugged in as well.
3 power up, get video and sad mac tone.
Machine was put to sleep using System 7.0. I re-cored the battery with a 6v 4.5Ah gel cell. The original Gates battery was 5Ah, but this one fits in the old battery case nicely. I believe the machine uses the same amount of power whether its shut down/"turned off" as when its put into sleep mode booted into an OS. My machine has a modem and 4MB RAM card installed.Something is wrong then, was that off or in sleep mode? What did you recell the battery with? Mine sat thirty days without issue in both so maybe you just closed the lid while it was on?
that sounds like my m5126 it does the same thing pretty much.my Portable can exhaust a 4.5Ah gel cell in 2 or so days just sitting in standby
I'm coming in to this discussion a bit late, but did you try removing your RAM card and modem? At one stage, I had a third party 7MB RAM expansion card in my my backlit portable (IIRC, it went in the PDS slot, because the machine was never built to take that much RAM in the RAM expansion slot) and it hoofed through power when on standby. The RAM card consumed so much power that when in standby, two ICs were warm to the touch! It was replaced under warranty, but the new one was the same - I guess it was just a poor and non-compliant design. In the end, I replaced it with a different type of RAM expansion card and the problem went away. I still have the old card kicking around somewhere - it seems too good to throw out, since it cost some serious $$$ back in the day!my Portable can exhaust a 4.5Ah gel cell in 2 or so days just sitting in standby
