Again, to be clear, we do not disagree on the sequencing. That's exactly why I said nothing when you first advised to check the ROMs. It's only AFTER he experienced what I'd silently expected to be a null result that I chimed in. That was not an accident on my part. I waited until he reported on the outcome of Step 1.
So, by all means, having a person check the ROM/RAM as a first step is the smart and easy thing to do. In most cases involving the later compacts, however, that will not fix the problem. Just as easy is to see whether there are telltale smudges around the capacitors. That's why I chimed in with Step 2. And anyone advising someone who is troubleshooting this problem should mention the capacitors because they are a known cause of the largest fraction (by far) of these symptoms. Yes, I've seen a couple instances of bad sockets, but I've seen vastly more instances of leaking caps. So, in my experience (yes, it's a limited sample, but at this point, I'm willing to declare that my sample size is much larger than most people's), the statistics support a focus on the capacitors. Sure, many other faults could cause the symptoms in principle, but it's the capacitors that typically do cause the symptoms in practice.
