Half-AA, primary (non-rechargeable). Try the eBay seller ronaldo101 if you can wait for the post.3,6v lithium again try radio shack but i dont know the form factor
All the more reason to pay USD5 each from an eBay seller. The colours will depend as you buy French SAFT (green and white), Israeli Tadiran (purple and green) or US Maxell (bright red and white). At that price, who needs Ratty Shark?if I remember correctly, it's a purple and green and black thing. It costs $15 at rat shack. more expensive than the one in my plus. And to make things worse, I need about 5 of the buggers...
That's ridiculous, the machines themselves aren't worth that much - they seem to work fine without the battery, cheaper just to buy a watch if you need to know the right time when using the Mac!If you can find a 4.5-V cylindrical alkaline battery (128K to Plus) anywhere, you may find yourself looking at USD30 each.
You are at perfect liberty not to use batteries if you choose to do so. Your decision in no way, however, changes the scarcity or the price of the relevant batteries for the early 68000 Macs, which alone was my point.... That's ridiculous, the machines themselves aren't worth that much - they seem to work fine without the battery, cheaper just to buy a watch if you need to know the right time when using the Mac!
You can probably quite safely wager your retirement fund that they were not made specially for use in Macs. Several companies, which Apple used to list in its Knowledge Base, made such batteries (eg Eveready 523), but it is probably safe to believe that the batteries were designed for another purpose than for Macs. It is also probably safe to believe that the demise of those other uses is the reason why the batteries are now scarce and pricey. Last time I bought one, there was a Chinese-made equivalent that was obligingly labelled with the type numbers of all the brands that it could replace: A21/A133, 523, PX21, EN133A and PC133A.I was just expressing surprise at how a small battery could cost so much, and also why anyone would buy one for an old Mac (presumably someone does? I don't know - do these batteries have any other common uses?).
That's very true, although it is so easy to prevent by leaving the Macs with wall and rear mains switches (68030s and older, with what Apple calls 'passive power control', and the CC and other LCs with pseudo-soft or 'active power control') left permanently on.... It is always good when you liberate a Mac and find that the battery still works, although with most 68K's that is a very rare occurance.
Last autumn I had 6 old Macs running all afternoon in a room and the temperature of the room got to 35 degrees Celcius (according to a thermometer on the wall), even though it was about 15 degrees outside. I also had my G4 running in that room with a 17" CRT, which both kick out a bit of heat when they've been on for a while.... 20+ Macs in a room take the edge off the cold, in winter, very well.
de
