Pretty much. I don't remember what 1 MB SIMMs cost in the 1980s, except that they were serious money.Fascinating. So it really was just a (complicated) SimmSaver-type device?
Or you can get a relatively cheap external 800k drive?Yes, the Mac Plus is indeed reporting 2Mb of RAM. There seems to be no other indication of that RAM expansions impact on the system. Seems to work as fast (or slow) as a Plus would.
I did work out a way to make a *reasonably* reliable 800k disk from a standard 1.4Mb HD one. As the issue seems to be the coercivity of the newer HD media (essentially the magnetic field required to write onto a HD disk needs to be a LOT more than to a DD 800k disk). Any residual data on the HD floppy written by a previous corresponding HD drive is difficult for a DD 800k drive write process to overcome. By using a tape head demagnetizer to completely erase the HD floppy beforehand, and therefore removing any residual magnetic imprint, the drive was then easily able to format and write to the erased floppy. Taping over the HD hole on the back of the disk tells the Mac drive that it is a DD 800k disk.
I formatted about 8 HD disks this way, only one required a second erasure with the demagnetizer.
I was then unpleasantly amazed at how often you need to swap disks between the system disk and the application... holy cow.
Thanks again,
Steve
Yup, that's right :I forget exactly how, but there is a way to change which system you are using by perhaps pressing command-option and double clicking on the finder on the disk you want to use, or something similar.
Same thing to switch to MultiFinder on the same disk. Can’t switch back, though.Yup, that's right :
I do have a Floppy Emu, but its currently wired into my //c. I do have a ZuluSCSI, but I am yet to work out if it can do the simple file transfer like the BlueSCSI on which its based. I'm not sure if it can, and I don't want to go to the trouble of creating HD images just for random program transferring. If anyone knows if the ZuluSCSI can do file transferring in a simple way like the BlueSCSI, I would love to know.Use a Floppy Emu in HD20 emulation mode.
I may also have one other bit of marketing info on the 1+1, plus maybe some tech info and Q&A. I am remembering a bit more after thinking about this stuff.
I am currently looking for an external floppy or HD (Macintosh original, not 3rd party) for the Plus.Or you can get a relatively cheap external 800k drive?
I have also ordered another 2x 2Mb RAM SIMMS, to put into the system. I might get a total of 4x and do away with the 3rd party RAM expansion. If anybody is a collector and would find value in owning it, I would gladly swap it for an external HD or Floppy for the Plus..?!?
Yes, I have used a few of those stock images for the ZuluSCSI. But unless I am mistaken, I believe that you cannot just drop a single "program" onto the ZuluSCSI SD card unless its an image of some sort. This would mean that you have to create an image containing that program in an emulator, and then save that image as a .hda that can be placed on the SD card and read by the ZuluSCSI. Is this correct? I believe that Blue SCSI have a way to transfer single programs that are not imaged, but not on the ZuluSCSI. I am more than interested to know if ZuluSCSI also have this facility.There are a bunch of stock boot images online for all the different emulators, including blank volumes (or take LaPorta up on the offer). No need to create them. Also, maybe consider getting another Floppy Emu so that you can have one dedicated to the Mac side...or even just for that machine.
Adding more RAM won't speed up the computer (unless maybe if you enlarge the disk cache in the Memory control panel). The main benefit is that you can run programs that require more RAM and that you couldn't run otherwise. Or you can run multiple programs at once under Multifinder.There seems to be no other indication of that RAM expansions impact on the system. Seems to work as fast (or slow) as a Plus would.
Hi BMOW,Adding more RAM won't speed up the computer (unless maybe if you enlarge the disk cache in the Memory control panel). The main benefit is that you can run programs that require more RAM and that you couldn't run otherwise. Or you can run multiple programs at once under Multifinder.
