Big Bird
I pulled three IIsis out of storage that worked when I put them away over a year ago, and now two of them have dead power supplies. I was able to narrow the problem down to just the power supplies by swapping components into and from the working unit. Last night, I tore into the power supplies. Swapping the AC input connector from the working power supply into either of the non-working ones fails to fix the problem. The fuses check good. All of the components on the board level that I can figure out to test have continuity.
When power is applied to the machine with either of the two non-working power supplies, the green light connected to the logic board flashes momentarily and the fan grunts. The relay in the power supply itself momentarily connects, then disconnects.
Any ideas on what could be causing the relay to kick back out and preventing the power supply from initiating a complete startup? I'm sure there's someone here with more technical/electrical knowledge than myself that could be of help. Thanks!
