pb3623
Losing my mind, y'all...
Got a Iici last week in great shape (though I really wish it had the programmer/reset switches for aesthetics).
Included was 20 MB RAM, a Radius PrecisionColor 8xj, and a Quantum Trailblazer ~850 MB SCSI HD.
What was interesting about this (in that I'd never seen this before) is that it had a "Quality Tested & Certified" sticker from APS Technologies with a barcoded serial number.
I was able to temporarily install my Turbo040 card and Apple NuBus NIC before happily installing 7.5.5. I installed the Radiusware stuff but was stuck at 640x480. But that's a minor inconvenience for now...
I wasn't quite sure was APS was or why FWB, Lido, or HD SC Setup wouldn't detect the drive (but clearly it's bootable).
MacEnvy, TattleTech, etc all identified the CharisMac (Anubis?) driver so I downloaded the Anubis tools, which detected the drive and I attempted to change the drive icon, of all things...
Whether that upset the SCSI gods, I don't know, but here's the deal: I can't boot (normal, Extensions Mgr or Extensions Off) from this drive or a floppy with the HD connected.
PRAM Reset: no change
Normal Boot: Extensions load without an issue, cut to blank desktop with MultiFinder and 040 menubar icon, then menubar, then bomb - "Finder - Unimplemented Trap" error and Restart
Cmd-Shift Boot: Bombs on "EM Manager" as soon as the Extensions Manager loads, same error + Restart
Shift Boot: same bomb/error
Boot from Floppy (7.5.5 Disk Tools): same bomb/error, unless hard drive is disconnected, then it boots! So it's got to be the drive, but this isn't useful since I can't mount the drive after the system's booted.
24/32-bit Mode: no effect, same results
Turbo040 vs. Cache Card vs. No Card: same results
So it's either the driver on the drive or something like a corrupt Desktop DB file that is crashing Finder - that's my theory at this moment.
But I can't mount the drive so I can't even format the damn thing - not that I want to... but if I have to, I'm dual-booting with A/UX like my other capable machines.
The only things I've yet to try are to #1 mount the hard drive from the external SCSI port (perhaps it's a bus issue but unlikely), or #2 change the ID and mount in another machine.
Can I get out of this unscathed? I don't know, but I'm confident Ye Old 68k Gurus can answer the call to action!
Thanks!
Thanks!
