AndiS
Hi!
I have a Mac Classic that is working fine but has a wobbly screen. The "wobblyness" is more apparent at the top and can be linked to Harddrive activity. Moving e.g. a white window in front of a dark background does not skew or wobble the screen!
I'm in the process of completely rebuilding/restoring the Classic from two non-working machines, so I'm not unhappy with my current progress, but this has to be resolved of course.
Here is what I've done until now:
The wobbly screen was apparent before the re-cap. So even altough there have been some leaky caps, this was not causing the issue. Wobblyness is linked to drive activity, but since I'm using a SCSI2SD, power demand from the HD should also not be the issue.
Any ideas how to continue? I found some Threads about changing some addidional diodes and/or optocouplers, but I'm a bit lost there at the moment.
BTW: The Analog board is a 240V European model - There is a sticker with "630-0420 240V" on it. I'm aware that there are different revisions, I'm not sure which one this is. - Even more interesting, the back cover on the solder side states that changing the Jumper JP1 changes the configuration from 240V to 120V. I thought that these Logic Boards where non-interchangable?
- - The obvious cleaning and a bit of Retrobriting
- - Recapped the Logic Board - The caps already showed some minor leaking underneath, so it was high time.
- - Recapped the Analog Board. - I replaced all the electrolytics, quite a few of them had also started to leak alredy, but no visible damage yet.
- - Replaced he Harddrive with a SCSCI2SD which is working fine.
