So got a replacement classic board in. Everything on it works great, however, when I plug in a ram expansion card (with 2x1mb sims installed) I get a sad Mac. Unplug the expansion card, boots with no issue.
What I’ve tried so far:
- Unplugged additional sims and change the jumper to no simms installed
- Plugged in another ram expansion card from working Mac classic
- Plugged this ram expansion into another known good classic (worked without issue)
- ran continuity test on all traces I could follow under the board
I’ve narrowed it down to an issue the logic board has with ram expansion cards. Also the logic board has been most likely recapped as the board has been cleaned and the caps aren’t original and one is a tantalum.
Any ideas of what to try next?
