That could very well have been the same opto-coupler problem in the power supply that I saw on numerous PF series monitors. In those, the vertical output IC was the first to succumb to the over-voltage but it's entirely possible that a different monitor would blow the HOT instead.The problem I had with monitors, I would get them running again, just for them to scramble up and short the HOT after maybe an hour or more of operation. You knew when it was going to do it, as the screen would slowly get wider, then the picture would loose sync and the infamous squeek, tick-tick-tick-tick of the SMPS when the HOT goes short.
Replace the HOT, and it was good to go for anywhere up to another hour, to days... Never figured htat one out. It was a viewsonic if I remember correctly. I had an apple powermac 5300 do that too. would randomly short the HOT.
it was always the ones that shorted the HOT or had other random horizontal issues that drove me nuts. All the other stuff was easy.
Most of the time when I ran into chronic blown HOTs, it was bad capacitors causing weak horizontal drive. Either the drive level was too low or the waveform was ugly, either way the HOT would spend too much time in its linear region where it is acting like a resistor rather than switched fully on or off and the result is a tremendous amount of heat and a fried HOT.
The horizontal deflection circuit, traditionally combined with the HV circuit but frequently separated in multisync monitors, is a resonant tank with a great deal of current circulating around. Everything has to be just right or things get ugly really fast. A 150W bulb in series with B+ would often prevent the HOT from blowing up so you could run it long enough to see what was going on.
