Hello,
I am trying to find an easier way of converting files created in old word processing applications from Mac OS Classic to Mac OS X.
The solution I've had is to save from the old word processors (WriteNow, FullWrite) to RTF which can then be (theoretically) opened in Pages under Mac OS X. This works for most text, unless special characters are used. In those cases, odd conversions can occur. In one example, an extra space is added after the special character, so something like "jalapeño" would appear in Pages as "jalapeñ o". Search and replace could be an option, unless a word ended in a special character in which case two words would then be run together. I figure there must be a difference in character encoding that is resulting in the problem.
The workaround I've found is to take the RTF file and import it into a PageMaker 6.0 document. Then, transfer that file to Mac OS X, open the PageMaker 6.0 document in InDesign CS6 and grab the text from there. If I do that, the special characters appear as they should.
Seems to me there should be an easier way. Any ideas?
Thanks!
Thanks!
