uniserver
What are you working on? Give us 68kmlaer's an idea of what projects you are working on or have planned.
- if its just to take apart a machine to check for Cap leakage or Battery leakage.
- if you plan to add ram into your machine one day
- if you are re-capping something right now, or plan to.
- remedial or super advanced
- A Jerry Rig or a OEM replacement, let us know what your doing, nobody will make fun of you in this thread.
What i have planned:
- Re-cap my IIgs, the big round cap is leaking and crusty.
- REtrofit a LC PSU board into an Apple II PSU , just to see if it will function with out -12v
- Diagnose or replace the Voltage regulators in my Macintosh Portable to fix hard drive spin-up issues running from battery.
- Fix My Caddy External SCSI Apple 300, it plays music cd's but will not read data from a stamped or burned data cd.
- Install my retro fit LC PSU in a Beater Apple II i have in the the garage,
- Glue 2 keys from some broken keyboard to the missing stubs on my apple II beater
- Test Super Serial Apple II card to see if it will work with out -12v ( highly doubtful )
- Over Clock my Quadra 610 board from 20mhz to 25or28or30Mhz +maybe More, (need 12.5mhz oscillator for 25mhz) (need 15mhz oscillator for 30mhz)
once over clocked check cooling, check for complete functionality, including serial ports and Booting From floppy.
- Change oscillator in my IIci just to see what happens, Maybe get more speed out of the cpu?
- OC my Quadra 700
- Install the Japanese keyboard from my not working Japanese PB160 into my PC170, Paint the Powerbook 170 to match SE PB 170 released in japan only.
- Replace the Sound IC's in one of my IIsi's that has a Very odd and strange sound output issue, diagnosed by mcdermd.
- take my (2) 5260's out of my closet and throw them in the yard
nobody wants them, drive over them with military truck for fun
- Downgrade my upgraded 128k, to original, or maybe figure out a 128k/512k jumper toggle set up.
- install a harddrive in my LC575, Find a rear IO plate for it as well.
- install mac os 8.1 on my LC475, then take the hard drive out and install that in my Color Classic, See if the LC575 board will work, and allow me to use native rez of the CC unmodified tube.
- Try to fix my LC-III the one that suffered a massive battery explosion. This one will require massive amount of time. off the bat needs 8+ traces re-run on the PCB
- Turn one of the nifty PowerPC CPU Peltier coolers I got from Trag, into an actual beer can cooler! Good one for the upcoming warmer weather
- Try to install higher capacity RAM chips in BANK A of my IIsi - Idea from JT.
- On the idea of ram chips, Install more ram chips or higher capacity ones in my LC - Idea from OlePigeon
- Work on ROM Modification , for my LC475 /w added ROM SLOT, from Mcdermd
- Motivate Mcdermd to get the (battery exploded) LC-I board I sent him for Ram Slots Removal for CC_333's SE/30, Working again, - will still work w/o ram slots,
and then pester him to also try and upgrade the ram chips on board, for the fun of it
(I think he is in the market for a hot-air-re-flow tool) * wiggles eye brows *
- OC my Quadra 700
