lisaem 1.2.6 released - video bug fixes
sunder
LisaEm 1.2.6 has been released. As usual, it can be downloaded from http://lisaem.sunder.net/downloads.html
This version, like the last few is all bug fixes - this time to the video system.
2007.12.03 - fixed win32 rawbitmap issues, this should speed up the display
quite a bit. Linux rawbitmaps don't work yet, just show a blank
white display.
2007.12.01 - fixed bugs on skinless on OS X. Issue with wxBitmap, it needed
to be filled in before using. Some update to wxWidgets changed
the default from the default being white, to an alpha background
causing the whole display to fail to update at all since the
data inside the wxBitmap was invisible.
- bug report - libexpat was accidentally turned on in the OS X
version of LisaEm, this is not needed by LisaEm's use of
wxWidgets, it will be removed via --without-expat in
wxWidgets' configure script.
If you'd like to support this project, you can do so by sending me something from my Amazon wish list. (Used books and DVD's are perfectly fine with me.) The trains are for my kid. :) http://www.amazon.com/gp/registry/wishlist/14EOBF86ARMDT
