If you get an LC575 board, make sure you also get the back panel off an LC575, as the LC575 board has the Communications Slot, which the LC520 and 550 lack. While it should be possible to use the LC575 board with your existing back panel, you won't be able to use the Communications Slot, and you might not be able to use the PDS slot either, depending on whether the PDS slot was moved in the 575 (its been a while since I've dealt with an LC575, I can't remember if they moved the PDS slot to make room for the Comms Slot or not)
