LC475 complains system 7.1 is too old (no boot)
belzrebuth
Yes, if you could share an image that would be great.Thanks:)
The 7.5.3 image I've used was a minimal install.
My workaround was to make a larger blank HD image, mount both and copy the system folder to the larger volume and then keep that just to have space to install some software.
BTW have you managed to get the daynaport emulation networking going?
belzrebuth
Oh no, I've actually had this image on my BII.
I thought it wouldn't be of much use for the RASCSI because it's .dsk
So can I just ssh it into the RACSI images folder and mount it?
I've watched that video but things aren't working so well for me.
Everything goes smooth as per the video but the 68k mac can't find a Powerbook G4 via Appletalk.
Perhaps it's user error or something because the PB is running 10.4.11 so I need to try with another mac w 0S9 or older to verify.
Nixontheknight
yes, the RASCSI has a web interface you can import DSK files onto, there was a bug with big files but they might have fixed that by now
belzrebuth
As before; I've tried to ssh the file you posted into /home/pi/images but it doesn't show up in the web ui in the list of image files.
I may need to create a 2GB drive from within the web ui attach it to basilisk along with the .dsk image and clone the .dsk into the .hda file for it to be seen.
Did you just upload this .dsk file to RAscsi and mounted it?!
I am not able to do that with the file as-is.
Nixontheknight
Let me clarify, I have never used a rascsi, only the SCSI2SD
