LC Video distortion after recap
elemenoh
The recap on this LC went OK (no lifted pads), but video is distorted. The area around all the caps was thoroughly scrubbed with IPA several times. I also removed and cleaned underneath the ICs near the cluster of  caps near the audio I/O.
Removing the extra VRAM/DRAM doesn't change the symptom. The distortion will change in pattern a bit when switching between color modes and B/W.
I haven't noticed any obviously broken traces, but also haven't looked super closely yet.
Is there any area of the board that should be focused on to hunt the issue down?
superpete
Having a similar issue with a lc575. In b/W you can see the lines which makes me think I've done something to an address line.IMG_20200405_104427.jpg
MrFahrenheit
What caps did you use?  Electrolytic or tantalum or ?  What was the rating on them?  If they’re tantalum the resistance and “wobble frequency” matters (can’t remember what it’s called at the moment).
techknight
yea, likely broken trace or via, or when you recapped, you have blobbed solder over to something that you shouldnt have.
Always double and triple check your work, especially if this symptom was created AFTER the recap.
