LC II recapped but still white screen and boots in a while
d3jsp
Got an old LC II out of storage. It will turn on, the harddrive will spin and sit at white screen for ~30 minutes before the startup chime and boots from the original scsi drive. After that, if I leave the power on, I can reboot and it will chime right away and works perfectly. I thought this was an obvious cap issue.
Here is the strange part: Just replaced all 17 caps on the board here: https://recapamac.com.au/macintosh-lcii/ and it behaves exactly the same... When booting cold, it sits at white screen, chimes after 30 minutes, then boots.
There has to be some other caps on the board causing behavior this right?
d3jsp
yeah, power supply is fine. 5V/-5V/12V. Plus, once the computer boots it works just fine
d3jsp
actually after recapping, now it takes exactly 19 minutes from power to chime and boot. Authentic old Macintosh experience :)
Normally for those kinds of time scales I'd think it was something thermal, but that's perhaps a bit too precise for that. What's the tolerance around that 19 minute measurement / how consistent is it? Congratulations on finding a really weird failure mode!
d3jsp
It actually varies a bit depending on how long since it's been turned off! After several tests, fresh boot can take up to 22 minutes
OK - so please be aware this is something in the nature of a guess - but this really does sound thermal to me. By thermal I mean something like - there's a solder joint somewhere that's got a hairline crack in it and therefore is a very high resistance, as current trickles through it, it slowly warms up and expands. This could even be something like on the back of the connector on the logic board where the PSU wire connects.
When you checked the voltages when the computer was just sitting there, where did you check them? On the PSU connector, or did you verify power to major ICs? What measuring equipment have you got handy?
Zarwox
Perhaps the machine is held in reset state during this time? Check the state of the RESET signal. A good place is pin 15 on EGRET U10 I think. While you are there also maybe check the +5V sense line pin 12.
d3jsp
If I am measuring the correct pin (the first one on the second row), it's always at 5V during white screen as it waits to boot
d3jsp
and this time it booted in 7 minutes while I was messing around with the multimeter, strange! It has never booted this fast before
Chuckdubuque
Do you have a BlueSCSI or other SCSI emulator? Try booting from that to eliminate the HD. I've had long boot times from failing SCSI drives.
Scott Baret
Curious if it takes less time after a CONTROL-COMMAND-RESET reboot. I have an LCII in my lab that occasionally comes up to this screen and after a reset, it's fine. It has a working SCSI drive like yours and was recapped a few years ago.
d3jsp
oh you are right! CONTROL-COMMAND-RESET does seem to boot it faster. Weird.
Tried clearing the pram a few times but that didn't help
d3jsp
actually, listening closely to the speakers, there is the famous mac death chime a few seconds after a white screen comes up. It is very very faint, even with headphones. Not a caps issue because it's already been recapped and the sound is loud and clear after it boots.
What's weird is that it actually boings and boots just fine after that chime. It just sometimes takes a really really long time
