LC 520 power issues
Franklinstein
I have an LC 520, and it no workie.
I set it up, flick the rear power switch to on, and it makes a really quick (seemingly shorter than usual) CRT-energizing noise. I press the power button on the keyboard, and nothing else happens. Tried a few more times, nothin'.
I put a new battery in it, no dice. I've tried every other known Mac resurrection technique, and it's still dead.
So, I pulled the logic board and tested the power supply to the logic board, and I'm getting only a few millivolts, which doesn't seem right (it should supply at least +5v on one of those leads). So I'm guessing that it's the analog board, not the logic board.
I pulled the analog board out a little bit (I didn't want to disconnect all of the CRT leads) and looked for cold solder joints, burns, etc, and found nothing awry. I haven't removed the covers from any of the shielded areas yet, though, because I'd have to undo the CRT's cables to get at 'em.
Anybody else have one of these, or a similar model, that they've been able to resurrect? Or perhaps have a suggestion as to what part of the analog board could be dead?
equill
There have been three types of startup powering-on arrangement for Macs.
1) Nothing but a rear mains switch, as in Compact AIOs and some LCs, designated by Apple as 'passive power control'.
2) A so-called soft power key on the keyboard, but designated by Apple as 'active power control' mediated by an inbuilt power management unit (PMU), and no rear mains switch.
3) A limited group, beginning(?) with and exemplified by the Colour Classic, having both a soft power key on the keyboard and a rear mains switch, and characterized by Apple as pseudo-soft power Macs.
If your LC 520 has provision for startup from the keyboard, leave the rear mains switch on and allow the Mac to soak without startup for at least 24hr. This first switch-on after an interval without power will produce the klunk that you reported. When the will to start up reliably has been re-impressed on the Mac it is possible to switch it off at the rear for maintenance or for work on the logic board without getting the klunk after switch-on.
Whenever you try to start up the Mac, use only the power key. The rear switch should remain on for as long as the Mac is attached to the mains, both for reliable startup and for the sake of the PRAM battery. If all you get from the power key is a series of rapid clicks, still let the Mac stand with the rear switch on, and try at intervals to get startup. You will probably be successful, in distinct contrast to the state of affairs in the IIci, IIcx and Quadra 700 where a failure of the TRKL supply is terminal until the PSU has been repaired.
If the keyboard does not have a power key, believe that you need one. This pseudo-soft power characteristic has been rehearsed here and at 'Fritter, both/either of which will go into it in greater depth than I wish to repeat.
de
Franklinstein
As usual, equill, your advice was spot-on. However, after I left it plugged in for a day or so, I tried to press the keyboard power key, and it still just sat there. Slightly dismayed, I was about to give up for now and put it in storage (I don't have too much longer at home here). But, I decided first to try to jump-start it (remembering the antics of battery-dependent machines like the LC 475), so I quickly cycled the mains switch before pressing the keyboard button, and I got the [happy startup noise]! Yay!
I wouldn't have thought of leaving the thing plugged in for a day. Now I can load an OS on the thing before I put it in storage.
