LC 475 - switch from 68LC040 to the 68040 with FPU, what do I have to consider ?
mkuenzel
for example on E**y there is an offer for a "Motorola XC68040HRC25M Socket PGA179 CPU 25Mhz". Should this cpu work ?
It's just a straight swap. The only difficult is making sure you take care removing the old CPU. Best to use something thin that you can slip into the gap and then rotate to lift. Avoid screwdrivers off possible, avoid "twisting" if possible. Ideal is a dedicated CPU removal tool, but they seem hard to find.
Best might be a plastic prying tool.
MacKilRoy
The HRC processor should be fine if you choose to operate it at 33mhz with an overclock. It’s supposed to be a high temperature variant, meaning it runs at a lower temperate at stock speeds, apparently. I’d recommend a heatsink though, regardless.
