Picked up a Laserjet II ntx-- Powers on, then displays two red flashing LEDS, (Paper Jam and Paper Out)
When it powers up, I can hear a click then a second click the printer goes through the warm up and then shows the error
I know the fuser heat bulb is good. I'm wondering if the printer is shutting the fuser off.
I will check the fuser using the technical service procedure in the manual, and then check the DC power module.
Is there anything else I can check?
