I have it plugged into an Apple Design Keyboard's ADB port and it doesn't seem to be detecting the mouse at all (clicks and movement). I have a stock Apple Desktop Bus Mouse 2 that works fine on the same port.What's not working? I cant see why it wouldn't work. If it's not working entirely I'd try to confirm it's actually working at all on another machine if you can.
Hmm yeah, my stock mouse works fine...I've have had a couple of Kensington Trackballs for Mac (ADB) and a joystick and they worked from System 6 to 7.6.1 without a driver.
Check if a mouse works on those ports, and if yes, then something in the Mouse-in-a-Box is broken.
Ahhh! So that's what that weird shiny buildup is! I assumed it was glue or something! I'll definitely give it a good bath now. I have 70% Isopropyl as well.Replace the two caps you got up there by the wire harness. Though they look clean, any electrolytic caps older than 10 years should be suspect for replacement because they would leak over time.
Also, to me, it looks it took a soda bath long ago. Just before removing the caps:
- Dunk in warm water to loosen up and remove the old sugar.
- Then dunk and rinse out in acetone to remove any cap goo.
- Lastly rinse out in high proof alcohol (I use 70% or higher Isopropyl when I can find it.) and then let dry.
Without powering up the unit, it is hard to tell if the LEDs are Red or IR. A continuity check of the cable would be best.
Okay so, I left it in warm water for about 5 minutes, and rinsed it with alcohol. I don't have any acetone, but I didn't see any leakage whatsoever around the caps before the wash.Replace the two caps you got up there by the wire harness. Though they look clean, any electrolytic caps older than 10 years should be suspect for replacement because they would leak over time.
umm.. no, no, and umm no....Ahhh! So that's what that weird shiny buildup is! I assumed it was glue or something! I'll definitely give it a good bath now. I have 70% Isopropyl as well.
I did a check on the cable, and only 2 of the pins go all the way to the PCB: pins 1 and 3.
As far as I can tell, pins 4 and 2 don't matter for mice as they're for ground and the "power on" signal.
I also found that the metal plug (the mini-DIN casing) also registers on pin 1 with my voltmeter. Since pin 1 is for data... wouldn't that make it ground out?
I'll strip the outer insulation and see what the deal is. Also, I thought Pin 1 is supposed to be data, not ground?umm.. no, no, and umm no....
You have a break or short in the cable.
And the shield is ground. if you have pin 1 connected to shield, then pin 1 is ground. You should have power, ground, ADB Data, and Open Circuit.
Must be the break in the cable mucking up my tests, but I tested from each pin in the mini-DIN (with this graph for reference) to the pins on the PCB and found the opposite of your notes.Look at the attached photo with my notes.
