3lectr1cPPC
Just swapped to the second EMM and it does the SAME THING! What on earth???
Kinda bummed about that.
New development, the battery works but the computer doesn’t think it has one installed.
I unplugged it while on and it stayed on, then popped up the no reserve power remains message and went to sleep mode. I forced the system to freeze so that pop up wouldn’t show up, and it stayed running off the battery for a few minutes then died. But the computer doesn’t see the EMM at all clearly. Tried all three of the software utilities for these and none could see it.
Don’t think it’s an issue with the ribbons since I get voltage off the battery and the laptop runs off it.
Fun problem this is!
I also re wired my adapter to disconnect VBATT so I can boot the computer and test the battery. But I still can’t run off AC power and charge at the same time.
This EMM worked and tested good in all utilities before I rebuilt the battery.
I just tried in my PowerBook 540 (which the batteries actually came out, was testing in my 540c before) and the same thing happens. I wonder if the time sitting with no cells connected killed my EMM.
I got some of those but not all. It has to be making contact though because the pack WORKS, the computer just doesn’t think it’s there… such a strange failure. Is it even EMM related if both my EMMs do the same thing?
The positive line on one of the two did experience slight corrosion on the ribbon, near where it connected to the cells itself (not the contacts).
I also did try tonight running the Smart Probe in EMMpathy and it also failed to detect a battery at all.
Definitely not a contact issue. That cap visible does appear to be starting to leak though so I should probably go replace that. Is it the cause behind this issue? Don’t think so but it’s a step to take nonetheless.
I believe it’s associated with the battery but I’m not positive. I will say I’ve never heard someone say it was preventing one from starting up (like the duos) so I don’t think it’s part of the main DC/DC circuit.
My guess is that it was for battery charge.
