Iomega Jaz suddenly died
micheledipaola
Hi, I had a couple Jaz external drives (the green ones, 1 GB cartidge capacity) that I plugged in my Iici alternately, to play around and test them. The original PSU was included with one of them, so I could power up both, to discover that one was somehow faulty while accessing the cartridge, while the second one was working perfectly. So I created a backup cartridge, worked a couple of hours on it to move software etc...
the next morning, no power when I turned on the Jaz Drive - nothing with the other one too. Is the PSU dead? I cannot get any voltage from the pins indeed...
is a modern replacement ok with the pinout? I found a +5 / +12 with the same pins but... will they carry the same voltages? OR there are other known causes for this behavior? Any hint appreciated!
Snial
So how many people have Jaz drives? I have one, like @micheledipaola 's, but I think the only Jaz disk I have no longer works - the drive itself powers fine.
bibilit
Probably have two units, maybe a third somewhere.
One is 1Gb the other 2Gb. Not the more reliable devices… but PSUs are ok si far.
