Internal SCSI Extension cable?
oz390gta
I am doing a bit of modification to the inside of my Color Classic trying to fit a SSD solution. I need a move things around a little and I need a cable that can extend a 50 pin internal SCSI ribbon cable.
Any ideas?
CC_333
Hi,
I don't know about extending the existing cable, but it might just be simpler to get a longer one instead.
There were some PCs and Mac clones which used multi-device cables, and those are pretty long in some machines.
You could also get one out of a Quadra 900/950, or perhaps a Mac II.
I hope this helps. I don't really have any other ideas, unfortunately.
Hopefully someone else will chime in.
c
MinerAl
MinerAl
Anybody know if the SCSI ribbon is longer on the 5xx harness? They are interchangeable with the CC's.
Bunsen
Admin-Witchfinder-General
Or get a couple of crimp IDC connectors and some ribbon cable, and make one up to the desired length. If you don't have a proper crimping tool, a bench vise will do the job. Pliers even, if you're desperate. I did it with my teeth once, but I don't recommend that approach.
Trash80toHP_Mini
NIGHT STALKER
In that case, just get the IDC-50 male and lop off a redundant internal SCSI cable.
The ready-made cable is by far the most convenient.If not quite the most economical solution at $8.95, it's not far off. Even a single IDC-50M will be likely be a couple of bucks shipped.
