Trash80toHP_Mini
NIGHT STALKER
. . . for a 466 DA runnin' 9.x and a Quicksilver 02 runnin 9.2.2?
Any help would be greatly appreciated!
TIA
TIA
You could also try trawling the sonnettech support pages, and see if they ever made a suitable card.Get a couple cheap Sil3512 based cards / and flash them with wiebetech TCS1-1 firmware.No drivers to install, bootable. Only down side is only two ports and no OS 9 compatibility.
You got dat right! :approve:Trash don't do OS X
Easily! I've got, literally, over fifteen thousand dollars worth of vertical market CAD/CAM software alone from my sign business. It works fine, I know how to use it and it requires a 9.2.2 world (or less!) and I'm NOT about to upgrade Illustrator, Freehand, the rest of my graphics suite and all the rest of my productivity software when running what I've got under 9.x is plenty good enough! [] ]'>No OS X? How can you stand it?!
That's a USB flash drive? I don't think there are any SATA->USB converters, only USB->SATA. More likely to find a FW->USB converter. I think the MiniStack drive has this feature.I'll look into all the different SATA whatever adapters / to back up a 16 GB KeyChain
You *could* I guess boot into OS X for a file transfer at USB2.0 speeds, then reboot into OS 9 for the rest of your work. Just avert your eyesSystem Requirements / an available USB 2.0/1.1 or FireWire 400 port.
More info please.There's no USB2.0 support under OS 9. I'm not sure of the situation with SATA cards, but a little searching would probably turn up something. Try xlr8yourmac and the apple support forums
Sata card recommendations?
Don't go buying that on my say-so. Google so far has turned up exactly nothing that converts a USB device to a Firewire port.More likely to find a FW->USB converter. I think the MiniStack drive has this feature.System Requirements / an available USB 2.0/1.1 or FireWire 400 port.
Thanks for the lead! I'll get two! [] ]'>By chance I dropped a NEC based generic USB2 card in a graphite G4 running OS 9. Worked fine without drivers, it loaded a USB2 flash stick but I didn't test the speed, although it didn't work in a dual 1.8ghz G5 PCI (not the PCI-X model). This is the model $13 CAD http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=003053&cid=IOC.313.574
Two different studios, in two different rooms on two different floors . . . and no Firewire cables . . . so . . . no! [] ]'>Have you tried connecting your QS to you DA with a Firewire and Target Disk Mode?
That makes sense. And now that I think back, that G4 was running Panther and not Tiger.VIA cards are a problem because they use UHCI and not OHCI, or something like that. However I think starting with Tiger, UHCI is supported.
