iMac G4: No screen activity
EvieSigma
Young ThinkPad Apprentice
I picked up a 1.25GHz 17 inch iMac G4 at VCF East this weekend but despite being in very nice shape overall, it seems to be troubled. When you press the power button it bongs like normal and the internal fan spins, but the screen never comes on. I've already tried pulling the RAM (it was already upgraded to 2GB, nice!) and cleaning the slots but it had no effect, what else could I try? The only other thing I can think of is to pull the PRAM battery and press the PRAM reset button (assuming there is one), but I'm not sure if the problem here is with the display panel or the rest of the computer.
beachycove
Unfortunately, plenty of imac g4s have fried graphics chips, owing to poor cooling/ heavy use. I have one of earlier USB1 models that was similarly afflicted, and went through several replacement logic boards before finding one that worked.
Disassembly and reassembly is not that bad once you get into the way of it, but is not trivial.
Having said which, open it up and see if the video cable has been properly seated, Maybe someone was in there before it came your way; the cable is often disconnected just to get at the hard drive or RAM.
EvieSigma
Fried graphics chips? Jeez...I sure hope not.
What does the video cable look like? There's a lot of cables inside the iMac G4 and to be brutally honest, outside of the obvious IDE drive cables I don't know what the other ones are for.
EvieSigma
Thank you! The connector was still attached, but I disconnected and reconnected it and also pulled the PRAM battery to drain the PRAM too just in case. Sadly it had no effect, and I don't have an adapter from mini-VGA to VGA to see if the machine will output video externally.
