IIfx
Since I have come to the conclusion that the 40mb stock drive is most likely not usable, I will need to mount a 3.5 inch hard drive. Only problem is, I dont have the bracket and it does not look like the default bracket is universal.
You could say I am just insane for wanting to be so picky, but I dont want the drive sliding inside when I move it.
Just in case someone knows a trick to make the old 40mb drive, it spins fine. It does not make odd sounds. However the Apple SCSI tool does not want to format it, failing at the end of the process. Silverlining formatted it but System 7 install disks failed halfway though copying files due to a hard disk error. Then the mac bombed. Any other drive works fine, so its not a SCSI bus problem to my knowledge.
Now then, on to the original stock superdrive. Its pretty dead, spiting out any disk even if its good. I am sure it only needs a calibration or a cleaning, but on how to do so without destroying the drive I am never sure. (I used to have piles of spare Superdrives from past-away macs, but all my recent acquisitions have had dead superdrives. So now I have no spares in stock :/ )
Right now it has a superdrive borrowed from my IIsi, and it works fine.
