Well here are the Highlights of this little Clammy.
Screen is nice and bright
-HD is very loud compared to my other gray clam's original HD. It works fine though.
-I put the OS X 10.4 Server on it with code and everything (Even though the code is being used in the other Xserve at my school [Not my moodle Cluster Node] It stills works within my LAN because it seems thats as far as the code registry goes!)
-White Plastic is darker than my other gray clam (Most probably because of exposure to light ETC.) And no this is not the 366mhz with the same plastics as tangerine/blueberry it is 466mhz with fire wire.
-Battery is dead. I am going to swap the battery for another one (This gives me two dead batteries
-DVD-Drive is perfect.
-Plastics on bottom are nice.
