I know, my history with iBook G4s isn't all that fantastic. In my nature though I had to try... this little machine is another victim of the "fractured solder syndrome" that plagued so many iBook G4s. I can't help it though, I love these machines, their shape, their battery life... so when I found out this one was destined for the bin, I fought to save it. The mission succeeded just a few days ago.
- 1.07GHz PowerPC G4 Processor
- 768MB RAM
- 40GB HD
- Combo Drive
- ATI Mobility Radeon 9200
- 12.1" Display
- Mac OS X Leopard 10.5.7
I have to admit, one of the things I missed about these is their performance. They're pretty standard in terms of specs, but it seems very difficult to actually strain the hardware of the system. Even Leopard runs like a dream on it.
So... I still had to tackle down the fractured solder. The best solution would be to retouch the solder, but it's common knowledge that these will almost definitely fracture again, so the board needs to be supported. Contrary to popular belief a shim is not sufficient as it pushes down on the chip, but doesn't prevent heat expansion of the chip leads. So my newest solution is to hot glue the chip down, applying it thick, so the glue then acts as a shim too. This applies even pressure across the chip and the component leads without straining the case too much. It also pulls the chip down because hey, it's glue! Win/Win situation and it works great. I borrowed some parts off my old iBook, but I used the glue technique on the old one and it seems to have worked well too.
So what did I get with the iBook kit?
- iBook G4
- 2 relatively new batteries (7 hours runtime)
- iBook G4 "Getting Started" Manual
- Original Box with foam and cardboard sleeves
(Already had a charger for it, so that's covered)
So... lets see just how long this new one lasts! :lol:
Cheers
- MB
- 768MB RAM
- 40GB HD
- Combo Drive
- 12.1" Display
- iBook G4
Cheers
- MB
