yes i was running panther for a while under 128 mb on a imac G4 800 mhz and i can tell you it was no funJust make sure you put as much memory as you can afford into that thing, and you should be fine.
limiter? explain...That machine is capable of Leopard even, once you crack the limiter on the disc. It will have no problems with Tiger.
Sure they could.I wonder if someone could actually mod the code and add G3 support or a patch.
