dudejediknight
Well, it seems my beloved Clamshell has run into a bit of a problem. The screen doesn't want to light up anymore. It still seems to be working, since I can faintly see the desktop and everything. I opened it up enough to see that none of the connectors on the lower half were loose or noticably damaged. I haven't yet opened up the screen end of it, for lack of a take-apart manual for just the display section.
My research seems to indicate that it could either be the backlight bulb or the inverter board. Anybody have suggestions as to how I should proceed? What would be the best way to check which part is causing the problem? The screen itself is still in great shape, so I doubt a full transplant would be worth the trouble at this point. Other than the dim screen (and the previously mentioned dead battery), everything else is running fine.
I do have a Dual USB iBook with the dreaded logic board video problem which could donate parts to the Clamshell, provided they are actually compatible. My Clamshell has been a great machine since I got it (it's lasted way longer than the Dual USB one did), and I'd very much like to get it back up and running as soon as possible.
