I know somebody who likes playing with his pneumatic sheet metal working tool collection
almost as much as his Japanese pull saws. [
I don't understand the problem with the video in port, it should be an easy hack if you're using a Comm Slot NIC and an LC VidCard . . .
. . . remove one of the mounting lug nuts on the VidCard . . .
. . . drill the lug nut hole in the DA-19 connector/Backplane plate out to 3/16" diameter . . .
. . . remove the mounting bolt from your VGA adapter for the LC VidCard . . . funnel shaped
Mac VDO type adapter preferably
. . . drill the mounting bolt hole of the adapter out to the same diameter . . .
. . . lop off one end of a thin VGA cable like the one in my hand . . .
. . . feed it through the 3/16" holes and terminate it to a 15-20 pin male<->female plug kind of deal . . .
. . . terminate the short, lopped off part of the VGA cable to the matching socket/plug . . .
All you need to do is unplug the connection and when you pull out your drawer. and it's free and clear.
The card will be removable from the MoBo as well. One mounting lug is plenty for the VGA adapter, it seems like a quarter of my macs are missing one side or the other. Remove the RFI shielding from the LC Card cutout and the Mac VDO fits through vertically just fine. Horizontally you'll only only need to file the tiniest smidge off each side of the plastic shroud. The VGA cable's connector and Ferrite ring on the cable fit through without modification.
If you decide to change out the LC PDS Card, all you need to do is unhook the VGA-out cable from the adapter, unscrew the intact mounting bolt of the VGA adapter, pull through a bit of the slack on the VGA-in cable, pop off the card and the feed the VGA Adapter and its VGA cable tail through the slot access hole.
Did I mention the guy I know with the Japanese pull saws has pneumatic drills, a thin VGA cable and a Mac VDO adapter? [}
