Bondo for wood! [
You'll have to paint it anyway, along with the peripherals to get that Not-Snow-White-but-
Snowy-White-Design-Language in the V-Hack. (very
BTW)
It'll have to be ProtoMacSmooth unless you can figure out a way to texture the (paint?)
just right.
I don't recall it being Bondo branded, but ISTR a two part resin filler for wood that
should have a closer hardness to the plastic than old-school metallic auto body filler did to styrene back in my plastic model hacking days. * That was always a PITA because it was about as hard to sand as sheet metal so the surrounding plastic has a disturbing tendency to give way around it. That's when I learned to shape and smooth the joinery with files instead of "waving it up" with sandpaper.
For doing smoothing on this scale, you can make
hard sanding blocks by gluing your sanding paper to to blocks of wood (soft pads are your enemy!) so they'll act as big files for reshaping the floppy bezel's curvature to match the Classic's (shorter radius?) curves.
* Smooth the peripherals set and Classic to rough powder coat white or platinum?
** Kurt Vonnegut Jr. just built the model planes as a teenager. I was coming up with original and combination model hacks in my pre-teen years. I hadn't drawn the parallel between that and MacHacking until searching for that wood filler simile just now. Thanks for that blast from the past. =8-D
WOOT!!!!!! 8-o
< WATanget mode >
You've got me hooked now! This Classic notion of yours is probably the easiest bezel I've seen yet for patterning a vacuum forming buck!
You wouldn't want it see thru, because of the hacked innards, that'll have be ugly. However, back-painting thin clear plexi Graphite, Blueberry, iMac White or whatever teh 2004-
correct-TA
MacintoshClassic™ would have been would be killer!
I'll go along with beachy on the LCD, (have you fitted one already?) I pulled apart a DOA 2300c LCD and figure it would
almost-maybe just might work with the goiter's bits bent back at a right angle. I've been nosing around the lids of a 270c and 280c to c if they'd work out a bit better.
RESET!!!!!! 8-o
OK, yer killin' me with this one now, Al! The
shell of teh_2004-
correct-TA
MacintoshClassic™ (IRL typo just became part of the name! :lol: )
sorry about this stream of semi-coherence, but . . .
< spinoff from tangent mode >
The shell of your hacked classic can
BE the vacuum forming buck! :approve:
Since you're paying homage to the Classic series, the backpainting on the inner surface of the vacuum-formed acrylic would be the Classic form factor
encased in a glossy acrylic outer shell! Whoohoo! This bonks a bevy of birds with oneBB! [
When prepping the Classic as a buck, you'll need to make a few thickness adjustments for the plexi anyway, soooooo . . .
. . . a 2004 Classic would at the very least have a Flat Screen CRT to accent its classic curves . . .
. . . you'll have the entire
outside dimension of the Classic's shell to fit a Duo's LCD . . .
. . . reshape the curvature, depth and size of the CRT flange opening to perfectly match the Duo LCD of Choice . . .
. . . that's one of the easier procedures, you'll be leaving a flat round-edge rectangle for the LCD . . .
. . . the first painting step will be masking off the exact visible outline of the LCD on the backside of the clear bezel . . .
. . . second will be masking off the remainder of the bezel up to the ersatz CRT-Bezel interface . . .
. . . spray the remaining area black, this will be the back porch (non-pixellated) portion of the
Flat Screen CRT's face . . .
. . . this leaves the exposed LCD rectangle as the active area on the fake CRT in a sort of floating image effect . . .
. . . you'll need to shave the floppy slot back the thickness of the plexi for it to function properly . . .
. . . I'd do this by making a negative casting of the LC/605 slot in plaster or resin, leaving the "donor" intact . . .
. . . then vacuum form the same thickness plexi over the negative form to give you the proper positive buck section automagically . . .
. . . this technique would probably work nicely for the CRT section as well . . . hrmmm . . .
. . . gotta flip some images about in post processing whilst doing something else! :approve:
Long story short, Al, you'll be using your signature CC-Zip opening as the model for the positive casting process outlined above and you'll have updated the obsolete floppy slot to something a bit more useful in teh_2004-correct-TA
MacintoshCOLORClassic™! [}
< /WATanget mode >
What was it I was saying? :-/
< . . . shakes head, rearranging cobwebs a bit . . . eschews the very notion of proofreading . . . ambles off to nuke his VERY clod cup of undrunk coffee . . . >
