directive0
And looking on EvilBay I see a couple units up there that require some repair, mostly having to do with the display.
I'm a certified mechatronics technician, so repair doesn't scare me, but not knowing much about the eMate's build quality or source of replacement parts I cannot qualify how easily it would be to repair these guys. I have bad memories of buying a broken OLPC XO-1 and trying to repair a fully ripped flex-cable. Ugh.
So I see a seller with two broken emats with the descriptions:
"This unit has been tested with a test power adapter and powers on but does not pass the calibration page so needs service/repair or use for parts."
Which makes it sound like the digitizer is borked and would probably need to be replaced.
The other lists as
" This unit has been tested with a test power adapter and powers on/functions but has lines in the right half of display screen so needs service/repair or use for parts."
Which could be as simple as unseated contacts for the LCD, could be more serious. The seller asks 20 bones before shipping for both, no software or AC Adapter is included.
Generally I'm just wondering if it's worth my time to try and fix an eMate or hold out till I can find a working unit? :disapprove: Is this a good way to break into the world of eMates?
The other lists as
