There's stuff for OSX but I find nothing for the older OS's
Hmm, I can't actually fire up the installer for OS9 from the 950 as it fails to make minimum requirements.
Anyways, noob me somehow forgot to set the Appletalk port to the Ethernet connection.
So it seems the ghetto way to make it work on a mac is to use the LaserWriter 8 printer in the chooser as it sees it, thne select from a wide range of printers and hope one of them is the closest match to the LaserJet.
OR
I discovered that HP still supplies a driver for classic macs.
The software and utility download still works but the font installer does not want to download. :?: HP states that the minimum OS that it will work on is OS 8 but it unstuffed and installed fine on 7.6.1 short of a garbage script put in the startup items folder that I threw out.
Anyways, after that my "LaserWriter 8" printer no longer worked but "LaserWriter 8f" did work (Hmm, I don't recall that being there originally, thena gain I didn't keep track of what was installed so I'll see if it returns when I do a reinstall when my Appleshare server is up) and so I setup the printer using the appropriate printer descriprion I installed earlier and there we go.
