Hotline server for *nix
lighting
I'm trying to set up a hotline server for the classic mac crew over on SA forums, and I can't find a working hotline server daemon out there. shxd consistently segfaults when a user connects and mhxd prints several pages of errors when I try to build it. Are there any maintained forks out there?
netfreak
Yep, if you compile with any of the options (compression, ciphers, etc) you really need to install a number of libraries. Your basic stock "no options" install I think only really relies on libreadline and a small handful of others that may or may not be a default install with your chosen distribution.
