timtiger
That’s another long storyexport to a .sit
In the meantime I’ll integrate an „export as hfs volume“ feature for folders.
Cool! One additional vote for "floppy" support. I've seen many requests from ppl just getting into vintage Mac'ing who've acquired a pre-CD Mac with a duff hard drive. Bootable "Disk Tools" (and OS install) disk images are readily available, but with no way to create the (standard HFS) diskettes on a modern Mac (with USB floppy), it can be a real chicken/egg struggle getting the vintage Mac going again. I'd therefore vote for "floppy" first, then Zip, MO, etc... Just my 2c. Thanks for your efforts so far!!The most wanted feature, I‘ll prioritize it.
I found the page for Mar if you want to check it out:If you’re working on something that you want to encode/decode files, cross platform, that is 68k Mac compatible, check out Mar. Its an open source, 68k Mac-compatible version of tar, and it works better and faster than StuffIt, plus the files can be transferred to and from a non-HFS volume without losing bits.
I’ll try to find the URL again.
Ah great - very helpfulI found the page for Mar
I‘ll take a look at the format specs and let you know. Is it to be able to mount that images using DC?turning those raw disk images into DC 4.2
Yeah got itLaPorta is asking for the reverse feature
Thanks cheesestraws!libdc42
Not that unique, since I'm also in the same boat. Been transferring files either via CD or via an external hard drive between my MBP and my G3 to access files downloaded from the internet.Well, I think I am somewhat unique in the community. I have old Macs, new Macs, and nothing else. I don’t really use emulators. So, I either use the DC4.2 images to mount on real Macs, or make actual floppies from them. I can’t do either of the above with the .dsk raw images, and I also can’t mount them on my Macs. So, effectively there’s a lot of software I can’t access after I download it. That would not be the case with this cool tool you are developing!
I got one step further to handle dc 4.2 images in a better way by embedding libdc42 recommended by cheesestraws. Using this lib will make it possible to generate them. The lib is up and running!DC4.2 images
