J English Smith
Well, I may be backed into a tight corner. Just wondering if there is any way I can take the ingredients I have and make fire.
I have a Lombard drive that is noisy and failing. I hacked this one to run 10.4.11 and it is certainly a more pleasurable thing than running 9.x or 10.3.x And yet, taking a virgin IDE drive and getting from 10.4.6 to 10.4.11 is painful. So I was trying to be slick and get a drive enclosure, use Carbon Copy Cloner and copy the drive, then caddy it and boot up.
I have a new IDE 20 gb drive, with a clean Fat 32 format from my windows machine, but the enclosure I ordered was USB 2.0. When I plug that USB into the Lombard, it does not seem to recognize it as a drive. Not sure if the problem is the USB 2.0 or the drive format. My only options in Win are Fat 32 or NTFS.
I have access to Pismos, but no Mac newer than that. Anything I can do here? Or, at least, if I could get the USB 2.0 drive to a newer Mac, and I format to a Mac-recognized format, would I be able to install it as the HD and then copy the OS from the install disk?
I just thought it would be great to actually do this as a clone using CCC rather than have to build the whole thing up again on a Pismo and then swap to the Lombard. Ugh. Very time-consuming.
Advice appreciated...I didn't think about the USB 2.0/1.0 problem.
