HD SCSI for PowerMac 7600
indibil
Max is @max1zzz on these fora.
Send him a private message (PM) and ask him.
Okay, I'll contact him if plan A doesn't work. I tell you news. I attach HD photos that I bought.
If you look at the label, it includes the text LVD/SE. So this HD will allow me to terminate the SCSI chain? Should it have a jumper to activate it or is it already activated by default?
I will appreciate instructions on how I should configure the HD, my intention is to install OS7.6 and OS8 on it, in two partitions.
Since I have already bought the HD and the adapter, I will try first, otherwise I will contact MAX.
No, SE stands for Single Ended. It doesn't mean the disk has built in termination but is to do with how the data signals are sent electrically. Early SCSI was all SE, and a newer disk with SE means it is backwards compatible in that specific sense.
SE usually needs a jumper fitting to enable, but you'll want to grab the manual for the hard disk if it doesn't say on the label.
It varies depending on the disk sorry. The manual will help you. You'll want your disk terminated, and to set a scsi ID (on the adapter). The adapter will come with instructions, be warned the last one of those I bought came with a jumper shorting the LED output so you MUST check the jumpers before powering it up.
indibil
Okay, thank you very much.
When I have the material I will carry out tests and tell you my results, although I am afraid I will have to buy the MAX adapter...
Do you have photos of this adapter?
indibil
Hello, today I received the adapter. I have start with BlueSCSI 7.6 Install CD Image.
Well, it seems that it doesn't work, it recognizes the bus and the ID, but it gives me this message. Is it because of the termination?
What is "force single ended" option in the hard drive? it makes the same result, not supported.
I'm going to have to buy the good adapter.
Hello, today I received the adapter. Well, it seems that it doesn't work, it recognizes the bus and the ID, but it gives me this message. Is it because of the termination?
Not supported is fine, use the cracked version of the formatting tool... Give me a sec, I'll find a link.
indibil
Thank you! I'm going to try it and tell you!
P.S. Is it possible that on the 7600 the termination is in the CDROM unit?
Possibly, but if it is it will only be terminating 8 of the data lines on the disk. The disk or adapter needs to be terminating the rest.
Daniël
This drive may be one of the exceptions of wide disks working with only narrow termination applied. If it's showing up, and works reliably after formatting, it pretty much confirms that. A handful of U160 drives, and very few U320 drives, can work without the full bus terminated. Why some do and some don't, I really can't tell.
I have Seagate 2.5" U320 Savvios (IBM eServer branded) that work with the el cheapo adapter on a narrow terminated bus, for example.
Yes, that's what I was saying, in that case the disk would be terminating the rest of the bus, or just not care. What I was saying was that the CD isn't the reason the setup is working as it is only terminating some of the bus.
