Realitystorm
Hi Eric, did you put the ProDOS extension in your extensions folder? It's in the extensions folder of my bootable images and on the Apple IIe card's setup disks in the system folder. Without that your Macintosh system can't "see" ProDOS partitions and they won't mount on your desktop. When you say "any single partition that I made ProDOS that did not also have a mac partition never showed up", I assume you mean when you formatted a drive you had to have both prodos and mac partitions?@Realitystorm I did read through your guides and were helpful, but I was never able to create an exactly 32mb partition or have your images mount. As mentioned above any single partition that I made ProDOS that did not also have a mac partition never showed up. And the Apple HD utility would not allow me to create the correct size partition.
For the 1k smaller I had the same issue, the max size for a ProDOS partition is 32,767KB not 32MB
