Does Apple Parallel Interface card use a non-standard (non-PC) pin out? (aka PLEASE help me get a printer working with my Apple IIe)
macinbot
I have an Apple IIe with the Apple Parallel Interface card. I am attempting to get it working with an Okidata Microline 320 Turbo dot matrix printer. I am using the parallel port on the Oki in Epson FX compatibility mode.
Tried PR#1 to activate the printer, but it just hangs until I CONTROL + RESET.
bigmessowires
PR#1 will redirect all output to slot 1 instead of the screen, so you won't see anything displayed on the screen.
macinbot
After entering PR#1 + RETURN key, I tried typing
PRINT “HELLO”
And the hitting RETURN key and nothing transpired.
Any other suggestions? I’ve tried several cables to rule out a faulty one. This site states there’s special pin out variance that Apple Parallel card uses from standard PC parallel pin out, but I’m not sure if it applies here.
NJRoadfan
The pinout appears non-standard, so you'll have to wire an adapter. Another option is finding a Grappler+ card. Those are still fairly common and usually include the Centronics ribbon cable or a DB-25 port.
bigmessowires
PRINT “HELLO”
If it were working, you would expect the "P" to be printed as soon as you pressed the key, along with every other letter you type, not just the text "HELLO". I suspect your problem is somewhere in the configuration setup, or in the pinout as @NJRoadfan mentioned.
