Gets reset few times a week
Yoshihide
Does anyone have a clue to why the "Hours of Use" (the one you get in TechTool) gets reset a few times a week?
It should display something like 43000 hours since 2004/3/19, but about once or twice a week, TechTool would display 30 hours since 2004/3/19.
Since the manufacture date (2004/3/19) doesn't get reset, and only the hours of use, I'm guessing it's not the PRAM battery.
Has anyone experienced similar problems?
Yoshihide
Seems like the PRAM Hours of Use parameter won't record anything above 43690 Hours. After that, it returns back to 0.
Is there a limit to how much hours the PRAM can record? 43690 Hours seems quite an odd number to me.
~Coxy
Leader, Tactical Ops Unit
43690 hours = 2621440 minutes.
That makes me guess that somewhere in the PRAM is 18 bits for the total uptime count, which gets incremented every 10 minutes.
Nico
And then after reaching that number, the counter overflows and goes back to zero automatically. It's the same problem the Unix timestamp will face in 2038 on 32-bit computers.
