G3 300 MHz Vs. G4 500MHz
joshc
Ideally I would like a 1GHz G4 upgrade for my B&W G3, but I can't really afford that. So, the next best thing, a 500MHz G4...these go a lot cheaper than the 1GHz for obvious reasons. But is it still worth it?
The benchmark results on this page seem to suggest it is worth it, and this is based on a G3/400, not a 300MHz like mine.
http://www.xlr8yourmac.com/G4CARDS/MetaboxG4_450_2MB/index2.html
Thoughts?
Rodus
Are you using OS X? If so then the G4 500 will spank the G3 round the block and back. Whether it's worth the money or not is up to you.
Unknown_K
G3's in the 450 range are very cheap. I would buy a used g3 1Ghz before I invested the same amount of money into a g4-500.
All in all I wouldn't bother with anything over a g3-450, better off getting an AGP g4 with 133 memory bus and upgrading that.
