FWB NuBUS Jackhammer Incompatible with Fujitsu 2.3G MO Drive
trag
Have you tried more than one kind of media?
This is really grasping at straws, but I have a really vague recollection of there being some difference in behavior depending on whether the media has 512B per block (block, sector?) or whether it uses 1KB.
Don't the MO drives usually work fine without any special drivers installed? I mean, things like ejectability may be affected, but I remember my experience being, plug them in, boot up and they act like a removable media device.
It may depend on what low level driver one put on the media, i.e. what utility was used to initialize the disk.
Oh, have you tried different utilities to initialize the disk?
I think I have a copy of APS 4.7 around here somewhere...
I know I have a couple of Fujitsu CDs with their software, but I doubt it's later than you have, since they came with 640MB external drives. I really like those 640 external DynaMO drives. The cases are stylish.
olePigeon
The 640M, 1G, and 2.3G disks use 2048B sectors.
They work fine without any drivers, just like most cartridge systems. So long as the disk is inserted when you turn it on, it'll mount automatically. Otherwise you can just use a SCSI mounter of your choice (I use FWB Mounter, it seems to work better than SCSI Probe.)
I have tried probably 2 dozen different formatting utilities trying to get it to work. I got a 640 disk to work (sort of) when formatted with FWB, but it was really, really, really slow. So slow to the point of being unusable, and would eventually crash computer about 1/2 way through copying large amounts of data. However, I could not get FWB to format a 2.3G disk successfully. It would always crash. Drive 7 would work to format it, but I ran into the same issues as with just using the Fujitsu formatter. I thin LIDO worked as well for formatting, but same issue. Disks won't mount while the FWB card is installed.
128M and 230M disks seemed to format and work when formatted with FWB, but slower than if I were using the Fujitsu driver.
Keep in mind, the drive is not connected to the Jackhammer card. They're on the local BUS. So the Jackhammer is somehow interfering with the local BUS.
I think you mentioned that it may be treating it as one logical SCSI BUS? So I wonder if perhaps the Jackhammer card is indeed incompatible with the Fujtisu drive, and because of how it works as one logical BUS, it renders the local BUS incompatible as well.
@trag Do you think if the the SCSI Manager was patched in-ROM that it might make a difference? I tried using the system extension, but it didn't appear to do anything.
trag
What host machine are you testing on, again. SCSI Manager gets complicated because it's built into some stuff.
Quadra AVs and later (everything later is PPC) have SCSI Manager built into their ROM.
I **think** that the JackHammer card has a copy of SCSI Manager in it's on-board ROM.
And there is the loadable extension.
When there's more than one version, sometimes there can be conflicts, but not always. I have no idea how the System manages multiple attempts to load the same code.
But on a PPC machine or Quadra AV, you could attempt to load it up to three times. Once from host ROM, once from the JackHammer card and once if you have the extension installed.
And you only want to load it once.
Are you thinking of patching it into ROM using something like a ROMinator? It might make a difference on machines that don't already have it in ROM.
I encourage the experiment simply because if you can figure out how to patch an extension's functionality into ROM, that would be a great thing to be able to do to all the pre-AV machines with slots. But I don't have any way of knowing if it would solve your issue.
SCSI Manager could be a complete red herring.
I do know we had a brief visit from someone who seemed to have coded for Apple professionally, or similar experience at that level several years back, and in one discussion made it sound easy to patch SCSI Manager into a ROM -- like everyone just naturally knows how to do that.
Of course he didn't stick around long enough to provide detailed instructions. Sigh.
olePigeon
@trag Host machines is a Macintosh IIci.
DougG3 made me a ROM with the Daystar driver patched in. So he knows how, but it didn't feel right to ask him to do it for me. I dunno. I might just be out of luck.
I'm still hoping that the 2.3.6 driver might work, if we can ever track it down.
Franklinstein
Maybe turn it on after boot and use a mounter program for the disks?
Otherwise I don't have many suggestions here. MOs are awesome when they work but getting there can be a really frustrating experience. For some reason System 7 does NOT like to play nice with any of the 640MB MOs I try to use regardless of drive (various Fujitsu or Olympus), disk (Maxell, Fujitsu, Mitsubishi, Kyocera, etc), or software (SilverLining, FWB ToolKit, or B's Recorder), but OS 8 and later works fine with them and System 7 is good with any of the 230MB MOs. I haven't tried to use any Gigamos with classic Mac OS, mostly because I figure they'll be a hassle, at least in SCSI form, and also because I only have one SCSI version (1.3GB) and it's internal so that limits its usefulness as a transportable high-capacity storage medium.
olePigeon
My IIci is still out of commission so I haven't been able to test the 2.3.6 driver. However, I did read carefully through the ReadMe file for the 2.3.1 driver, and it states that the JackHammer is only compatible with 512 byte sector cartridges. It specifically states that it is not compatible with 1024b sector cartridges or larger. So that would explain why it doesn't work with anything above 640MB (they're all 2048b/sec.)
I did learn that the 540MB discs are still 512b/sector. I always thought it was kind of odd to have both 540MB and 640MB discs, but now it makes sense.
olePigeon
This is exactly the problem. :) Read back through this thread and you were spot on. Could have saved myself the trouble if I had thoroughly read the ReadMe file. The JackHammer is not compatible with cartridges that are larger than 512B/sector. The 640 and larger are all 2048B/sector. I'd have have to use 540MB or smaller, as the 540MB discs were the largest media to still use 512B. Or switch to 5.25" MO media, which are still 512B/sec for the 2.3GB discs (but the larger capacity discs are 1024 and 2048.)
trag
Thank you. I'm feeling very sleepy today -- probably oak pollen -- and that was a nice pick-me-up. It's always nice to have been right about something. :)
CC_333
I've been feeling quite lousy the past few days. i thought it was a cold or something other than covid, but then I looked up at the neighbor's sycamore trees and all the pollen they're spewing into our yard (said neighbor, of course, is upwind, so he gets almost none of it).
If anyone here knows what a sycamore is, you know how terrible their pollen is!
Has anyone tried to see if a work around for the 512B limitation is possible? Sorry if I seem dense....
c
MrFahrenheit
I thought my A/UX 3.0.1 bootable MO disk was 1.3GB (hence 2048b, which apparently doesn't work with A/UX), but it turns out I used a 540MB disk (retaining 512b).
I wish I had a Jackhammer to test with. My IIfx would sing.
trag
@trag In your experience, would you hazard a guess if it's a hardware limitation or driver limitation?
I have no idea, but if I had to guess, I'd guess driver limitation. The hardware ought to be able to just sling the bits off the disk, I would think. Of course, there might be low level hardware functionality in how the sectors are read, but that just doesn't seem consistent with how most disk technology is done.
I think. Willing to find I'm wildly wrong, even in my total uncertainty....
trag
I have rethought my guess a bit, seasoned with an old memory and now I'm leaning towards hardware -- or firmware.
I remembered an old (IIRC) Pinnacle Micro 5.25" drive which could operate on either type of media, but one had to change a jumper on the back, where one normally find the SCSI ID or Master/Slave jumpers.
Assuming that's a real memory and not something cobbled out of ghosts -- this would have been almost 30 years ago.
Might be worth a look on the problem drive to see if there are jumpers and if they're labeled. Of course a manual or datasheet would be even better if you can find one.
olePigeon
The Fujitsu drives I have can use any media automatically. Doesn't require jumpers. The jumpers just change SCSI termination, startup delay, enable/disable cache, etc.
